CV controlled resistance//opposite result obtained
jacopo1919
Joined Apr 12, 2020
115
hi everyone, i need an advice!
i'm relpacing this part of the decay section of a 808 bassdrum (pic1).
IF 500k resistance on decay pot= max decay, whereas at min. pot resistance= min. decay:
In order to voltage control that resistance, i'm using a vactrol (pic 2) but here my problem comes:
as more CV as i get, as less resistance i get out of the vactrol (more CV --> less decay, which means the opposite of what i want).
Any help on this much much appreciated!
cheers
jacopo1919
Joined Apr 12, 2020
115
Hello there :confused:
Does something like this sound good.
Version 1 by MR 808
Whenever Roland Service Notes speak of a “trick”, you know it’s going to be cool. In this case, it’s what gives the 808 & 909 their characteristic attack (that “crisp” bass sound). Another fun feature of this circuit is that it goes slightly flat (just like a real drum). Listen to the the 808 at maximum decay BOOOOooooommm…. hear it go flat?
Check This out & tell me what you think?
http://smd-records.com/tr808/?page_id=91
thanks! good stuff indeed, but basically it explains where are the G points of the decay section.
what i'm trying to achieve is control that decay resistance via voltage source!
What is the range of the control voltage?
will be approx 0 to +5v
Veracohr
Joined Jan 3, 2011
783
Edit: crutschow got to it first.
So add a circuit between the CV input and the transistor that inverts and shifts the CV so that 0V CV input gives max voltage at the transistor base, and max CV input gives minimum voltage at the transistor base.
Veracohr
Joined Jan 3, 2011
783
The buffer between the summer and the vactrol is unnecessary. I would instead buffer the offset pot from the summing amp. I would also move the CV pot to the input, that way you still have the same 100k input impedance, but now the pot is buffered from the summing amp.
38,767
Does your circuit give the desired proportional control of the decay versus input voltage?
If not, then there are ways to change the relationship between the two.
jacopo1919
Joined Apr 12, 2020
115
at the moment this is what i came up with and is working well! the decay is quite proportional to the CV input.
curious to know what you meant with those ways to change they relationships
in the next days will try out what you suggested!
indeed that was unnecessary!
38,767
Instead of having the vactrol control current proportional to the control voltage, you could add some elements, such as a diode or two, to make the current non-linear with voltage.
But if it's working okay for you as is, then there's no need to go into that.
