custom ic in low quantities
enjoykilian
Joined May 15, 2021
95
Hello
I am trying to create a 16 bit pic but can't find any website that let me buy a custom ic dip or smd format for low quantities (1-5 max)
I apreciate it if you answer
Papabravo
Joined Feb 24, 2006
22,111
Fergeddaboudit! It's not going to happen. Your best bet is to learn VHDL, or Verilog and program an FPGA to implement the processor you want. AFAIK that is the most likely alternative. Any other pathway will involve a large NRE (Non-Recurring Engineering) charge and a per unit cost in those quantities that will make your head spin. I'd be surprised if you could get any fab to respond to your query.
At one time you could get an NRE charge as low as $250,000 with a commitment to buy between 5000 to 10,000 chips at $50.00 each, but that was a long time ago.
BobTPH
Joined Jun 5, 2013
11,633
Hello
I can’t even imagine what you mean by this.
Do you want to design your own microcontroller to make 5 of them? That would be nuts.
Or do you just mean a standard PIC processor pre-programmed with your code? But that makes no sense either, you can program them yourself with a $50 investment.
Bob
enjoykilian
Joined May 15, 2021
95
i am just for educational purposes trying to make a 16 bit µC like a big arduino of some kind and make an own basic programing languange
250k?! thats a lot of money
Bob
yes i am trying to create my own custom computer like an bigger arduino o rasbarry pi sort of thing
What is the design application?
Educational purpuses
ronsimpson
Joined Oct 7, 2019
4,792
I think we many not be communication well.
There may be some confusion between a custom IC and a custom computer like a Arduino.
Some of us have made custom ICs but it is big money.
Many of us have made custom computers and it is not bad, but you need experience.
I have seen Arduino "kits" where all the parts come in a box and you need to solder them on the PCB. Not really a "make custom" but......it is a make.
Is this for you to teach? or is this for your education?
Papabravo
Joined Feb 24, 2006
22,111
I understand. For that purpose, you want an FPGA (Field Programmable Gate Array) with enough resources to implement a processor. In order to implement a processor in an FPGA you are going to need to learn one of two high level Hardware Description Languages (HDL). The current choices available with FPGA development tools are VHDL, and Verilog. You can find numerous books and web resources on each of these languages to use in conjunction with the documentation from the FPGA vendor. It is even possible that you can find open source implementations of current processors you may be familiar with.
https://en.wikipedia.org/wiki/VHDL
https://en.wikipedia.org/wiki/Verilog
Aim a lot lower.
Most of us have designed a simple processor in school for training.
A TTL design: https://github.com/dangrie158/SAP-1
Here is an FPGA example: http://simplecpudesign.com/simple_cpu_v1/index.html
MrSalts
Joined Apr 2, 2020
2,767
You went through this same dream sequence a few times on this site.
This was from last July.
TITLE: Course-16-or-8-bit-cpu
Hello
I am searching for a free online course about cpu's but more the old part of it because for educational purposes i want to desing and make a 16 bit (or 8 bit) cpu but i dont know everything already so i want a good course that covers the main stuff of a cpu (ram, alu, registers...) But also video output (vga) and audio output (3 to idk voices and all basic waveforms) and any kind of keyboard input (usb or ps/2) like a commodore 64 so i can program it.
Your help is much appreciated.
and this one from June...
https://forum.allaboutcircuits.com/threads/cpu-design-software.180213/post-1645448
Part of learning is getting a reference of knowing how much you don't know. And knowing what kind of a project is a one-person project vs a team vs a corporation vs ...
also, being able to estimate what is within a financial reality vs the available budget.
enjoykilian
Joined May 15, 2021
95
My education
enjoykilian
Joined May 15, 2021
95
Yeah i know i think i just love cpu's i will try and do something on a breadboard then
enjoykilian
Joined May 15, 2021
95
Aim a lot lower.
I looked into fpga before but didnt understand it really
Aim a lot lower.
I didn't realy think about fpga bc i dont realy understand it and i think i still got the same problem then bc i can't buy 1 piece of a custom ic and bc it's for educational purposes i dont need 10000 ic's
Papabravo
Joined Feb 24, 2006
22,111
The cool thing about an FPGA is that you can buy one of them and re program it any number of times. It is not like OTP (One Time Programmable) parts where you program them once and then have to throw them away when you want to make a change.
enjoykilian
Joined May 15, 2021
95
Ow i didn't know that thx a lot
BobTPH
Joined Jun 5, 2013
11,633
Here is a half-baked idea that has been kicking around in my head for a while:
Make 32-bit computer from functional blocks implemented on 8-bit microcontrollers.
For example, you might implement an 8-bit ALU slice, and use 4 of them to implement a 32-bit ALU.
Then have other blocks for memory controller, an instruction pipeline, etc. The architecture would be totally different than the micros it would run on and would have lots of RAM.
It would be interesting to see what kind of speed you could get.
Bob
Bob
It would be slow as hell.
MrSalts
Joined Apr 2, 2020
2,767
Bob
You just described hyper-threading. Most Intel commands do not need all 64-bits in a core most of the time. So, a processor can be split into two 32-bit "threads" two give two virtual cores.
Here is a primer...
https://www.tomshardware.com/reviews/hyper-threading-intel-definition,5746.html
And, since it is very efficient use of execution cycles, it doesn't slow anything down and this is not true...
