Custom BLDC ESC running into unfixable heating problems causing Death of MOSFETS. please help
HarryCL
Joined Oct 12, 2021
10
So, reiterating my previous questions:
Heatsinks on MOSFETs?
Vcc to IR210x?
Motor specs?
Currently the fets have no heat sinks, its just a small 900kv drone type bldc and vcc to the ir2101/3 (although the package says 2101 they are from ebay so they may be a 2103 underneath) is the same as the vcc to the motor 12v.
Irving
Joined Jan 30, 2016
5,167
A 'small' 900kV drone motor can still pull a shed load of current. Do you have a link to where you bought it?
Sounds like these eBay parts are dodgy, you'd never get a leading brand misnumbering them like that. Link?
HarryCL
Joined Oct 12, 2021
10
Irving
Joined Jan 30, 2016
5,167
Are you running the motor with no load or do you have a prop attached?
Can you measure the current drawn from the battery.
Irving
Joined Jan 30, 2016
5,167
The reason your MOSFETs are getting hot is because you are dissipating around 4 - 8W in each, possibly more (I can't be more accrate without knowing more about the motor than the data I found online). The MOSFETs can only handle around 1.5-2W without a heatsink. You need a heatsink with a thermal resistance less than 10degC/W on each MOSFET.
At no load that motor should be taking about 0.5A per phase. The fact its taking more and gettng hot is because your timing is wrong - with 50% duty cycle you're applying approx 6v which is 5,580rpm or 93rps. But your phase timing is for, I think, 63rps so you're not generating enough BEMF to keep current low and so everything is getting hot...
