current threshold protection circuit
Status
Not open for further replies.
artmaster547
Joined Jan 6, 2016
409
wayneh
Joined Sep 9, 2010
18,181
You need to be more precise about the output you want, as a function if the actual current. For instance, what do you want at +300A, or at -300A? Do you want an output proportional to the absolute value of the current, or do you want a digitized output (i.e. zero at any current below ±X amps, 5V at any current above ±X amps)?
artmaster547
Joined Jan 6, 2016
409
hi sorry yes I want this digitzed so zero if it is in between those two values, it is above +500V and below -500V then should remain high
Status
