Hello . Is there anything, a component or circuit, that regulates current like a voltage regulator regulates voltage. If so what is it, where can I find it or how do I build it. Thanks.
Sure. Just Google "constant current circuit" and lots of good stuff comes up.Hello . Is there anything, a component or circuit, that regulates current like a voltage regulator regulates voltage. If so what is it, where can I find it or how do I build it. Thanks.
2 amps and the supply voltage is 5 voltsLM334 -
http://www.ti.com/lit/gpn/lm334
What is the magnitude of the current you need to deliver, and what
is the power supply voltage the current source can get its power
from ?
Regards, Dana.
Hi,2 amps and the supply voltage is 5 volts
