It's down to the cell chemistry. Have a read of this.Any reason for damaging the cell !
You may be correct with your points.It's down to the cell chemistry. Have a read of this.
maybe not -- unless you use (perhaps multiple parallel) 2N3904 and 2N3906 . . . has to do with ICEO ICEX (i speculate !)5.3V it has to work !
When the supply voltage is only 5 volts, the 4 volts dropped by the TL431 leaves only 1 volt for your entire current regulator to operate on. This is not enough, largely because of the way you're biasing Q1 (see diagram, below).I still can figure out reason ! Without TL431 current regulator works and if i use TL431 it does not work.
Thanks !
Thanks for your time.When the supply voltage is only 5 volts, the 4 volts dropped by the TL431 leaves only 1 volt for your entire current regulator to operate on. This is not enough, largely because of the way you're biasing Q1 (see diagram, below).
The way you have the circuit right now, the minimum operating voltage for the current regulator is equal to the forward voltage of D1 plus the Vbe of Q2 plus the Vbe of Q1 plus the voltage across R2 needed to drive enough current through R2 to bias Q1 (roughly 15 mA divided by the gain of Q1).
Obviously, these voltages total more than 1 volt and therefore the circuit will not work on a 5 volt supply.
There is an easy fix for this problem: disconnect the upper end of R2 from Q1's collector and connect the upper end of R2 instead to your 5 volt supply. Thus, base current for Q1 will still be available even at the minimum supply voltage. This change will allow Q1 to almost saturate (in other words, with Vce almost zero) before the current goes out of regulation, allowing you to operate at a lower supply voltage.
Try this fix and see what happens.
No. You've designed this thing as a shunt voltage regulator (the TL431) driven by a constant current source, so constant current is what you're going to get whether the load is connected or not.It will draw the same current when load is not not connected i.e. 17-22mA. Is there any way to reduce this current ?
Here ya go...Thanks !
Could you please share your .asc file?
Regards,
by Jake Hertz
by Duane Benson
by Jake Hertz
