Current Mirror using MOSFETs
BrentM
Joined Oct 26, 2012
43
Hi, I am making a current mirror for one of my classes using NMOS transistors. The required reference, Id, current is roughly 1mA, and the desired load current is 100μA. Basically, in order to lower the current to the load I need to add a resistor going from the source of the second MOSFET to ground. I have attached a schematic of the design. Here is the work I have done so far:
MOSFET parameters: Kn = 111e-6, W/L = 3, Vt = 2 V
since 1mA reference current(Id) is desired, and we know that N1 is in saturation,
Id1 = (1/2)*(Kn)*(W/L)*(Vgs - Vt)^2
plugging in our values
1mA = (1/2)*(111e-6)*(3)*(Vgs - 2)^2
Vgs = 4.582 V
therefore the resistor, Rd:
Rd = (Vdd - Vgs) / Id = (12 V - 4.852 V) / (0.001) = 7.4kΩ
I know that my desired current, Is, is 100μA and is one tenth of the reference current, Id:
Is = Id / 10
I am having trouble calculating a value for Rs to get 100uA. Is there some way I should be manipulating the Id equation that I used above? Or should I be using simple voltage division and ohms law? Thanks for any help.
Brent
Ron H
Joined Apr 14, 2005
7,063
Vgs = 4.582 V
Is = Id / 10
Brent
Have you been told that you must add a resistor? The normal way of scaling currents is to scale transistor geometry (W and L).
Ron H
Joined Apr 14, 2005
7,063
It' pretty straightforward. Solve the Id equation for Vgs2 when Id=100uA. Getting Rs is simple once you have Vgs2.
Come back with your method and answer.
BrentM
Joined Oct 26, 2012
43
Ok that seems easy enough. So once I determine Vgs2, I can use ohms laws like this:
(Vgs2 - Vss) / (100uA) = Rs
Does that sound right?
BrentM
Joined Oct 26, 2012
43
Here is what I came up with:
@ 100uA, Vgs2 = 2.775 V and Vss = 0 V
Rs = (2.775 - 0) / (100uA) = 27.75k
Jony130
Joined Feb 17, 2009
5,600
No your answer is wrong. Voltage across Rs resistor is not equal to 2.775V.
Look at diagram and use KVL to find voltage across Rs.
PS. All so I get Vgs1 = 4.45072V and Vgs2 = 2.77498V and Rs = 16.7574KΩ = 16KΩ
BrentM
Joined Oct 26, 2012
43
using KVL I get Vd1 + Vss - (100uA)(Rs) = Vgs2?
so the gate voltage at the second transistor, Vg2, is 2.775V.
Vss = 0V
Am I on the right track?
Ron H
Joined Apr 14, 2005
7,063
That's what I get also.
BrentM
Joined Oct 26, 2012
43
I tried using the resistor value you came up with and I did not get a load current of 100uA. However when I used a value of 1.4k I get the desired load current.
Can you explain your process, I am clearly missing something.
Brent
Ron H
Joined Apr 14, 2005
7,063
Brent
Show us how you tested the 16k value, and how you got the 1.4k result.
BrentM
Joined Oct 26, 2012
43
I used MicroCap 10 to simulate the circuit. I have attached a schematic. V1 and V2 were both 12 VDC sources, and R2 is the load resistor(1k). When I simulate the current through resistor, R3, it's right around 45uA. However, if I change R3 to 1.4k, the current through it is right around 100uA.
Ron H
Joined Apr 14, 2005
7,063
Do both of your transistors have the parameters you specified in your first post? If not, then your simulation will not give you the correct results.
