The STP50N06 is the best choice because of the higher power rating.
You won't be able to get .001 ma accuracy. Lets say the pot turns 180 degrees. 0 will be 0 ma and 50k will be 5 amps. So each degree is about 28 ma. You could add a "fine" adjustment with a smaller pot in series with the 50k. But the resistance of the sense resistor will probably make it vary by more than .001ma. as it heats up.
