I guess the question is not so much, do I need a current limiting resistor, as do I need a voltage dropping resistor.
Pin 1 of this IC will sink 5mA when the charge voltage fall between .6V and .35V, at which point aprox. 5mA is sinked through D1(LED) and R1(Resistor).
Not really sure what I need, an LED that lights up well enough at 5mA?
Will an LED rated at 3V/20mA light up with a 400 ohm resistor in series and only 5mA passing through it?
datasheets-LTC4054L-4.2
