Current limiting circuit for adjustable negative voltage
Shamoooot
Joined Apr 3, 2023
65
Hello
Following to my previous question about making a circuit that allows adjustable voltage output and current limiting, and using LM2596 I was able to limit the current for the positive voltage using the circuit:
But I am having troubles with the negative voltage, and it doesn't work:
Need help what am I doing wrong, or maybe it can't be done?
ronsimpson
Joined Oct 7, 2019
4,888
With out commenting on the current limit circuit:
See the red traces. They are not "ground" but -V. The opamp and RV1 and RV2 need to be connected to -V.
People often forget how to connect Vin. I believe it is connected as shown in blue. D3a to (0V)
Hope this helps. RonS.
Shamoooot
Joined Apr 3, 2023
65
Hey RonS
Thank you very very much, the negative voltage is working now!.
Now need to figure out the current limiting part.
