Current limitation of a wireless power supplier
Quentin Girault
Joined Jun 21, 2018
Hi everybody !
I am working on a project where I want to make a platform to spin thanks to 4 embedded DC motors. So the supplying has to be wireless.
My problem is that the current limitation of the wireless receiver is to low. Then, when I control the motors (with labview connected to the embedded arduino nano by bluetooth), if the PWM value pass 80, everything stops for a second and the bluetooth is disconnected.
So I would like to find a wireless receiver that can provide more than 1100mA. Do you know if I can find one ? For now, I use a wireless android phone charger. Maybe I can override the current limitation by modifying it ?
Thanks for reading, don't hesitate if you have any question or advice :)
DickCappels
Joined Aug 21, 2008
10,662
You can get more power from conventional circuits by raising the voltage on the driving end and making the "antennas" (if that is what they are called) much larger.
Might it be easier to make a transformer with a pot core and place it in a shaft in the center of the platform where there are two coils within the pot core, one being stationary and driven with high frequency AC, the other coil rotating with the platform? I
https://en.wikipedia.org/wiki/Rotary_transformer
Quentin Girault
Joined Jun 21, 2018
Thank you for your answer. Okay, I think I understand.
I am not sure that the stationary emitter is supplied by high frequency AC. It is just connected to a computer with a USB cable with a little electronic circuit... For now, we are using a basic wireless supplier bought on amazon or aliexpress.
We will first try to put two receivers instead of one, to see if we can get more power. If it doesn't work we will follow your advice and try to make the antenna larger.
Hymie
Joined Mar 30, 2018
1,347
I would think that if you wired two of these in parallel you would have a fair chance of getting the output current you want.
https://www.ebay.co.uk/itm/Qi-Wirel...Android/253510345925?var=&hash=item3b0664e4c5
Many are available on ebay with specs claiming an output of 1000mA. I would not be surprised if that 1000mA is only achievable under optimum conditions – bear in mind that the unit spaced further from the charging base will have a lower output due to the reduced magnetic coupling.
Quentin Girault
Joined Jun 21, 2018
Can we see a picture of your platform and motors?
Sure !
Sorry for the (huge) delay, I'm working on serveral projects at the same time... here are some pictures
I changed the resistors just before the motors so now, we can send a PWM command of 255 (100%), but the platform is still slow as the current in the motors is low... the problem is still here.
We bought a more powerful power supply, maybe it will work... We will test it next week
Thank you for your answers !
Quentin
Kjeldgaard
Joined Apr 7, 2016
476
I have been close to writing something about:
Why is contact less energy transfer chosen when something so simple, but old-fashioned, as a slip ring may be able to handle the task.
Quentin Girault
Joined Jun 21, 2018
Hmmm that's a good idea. I don't know actually. I am just trying to make everything work with what I have. The project was already started when I arrived. If the wireless is definitly not working I'll suggest it.
But I have got an update. I tried to use two coils instead of one and I really can't understand what is happening... I drew something to explain, in the attached files.
Thanks for your help
