Current Limitation circuit or device
Grogu
Joined Nov 30, 2016
9
Hello all,
I'm new in electronics and i hope to find some help from you.
I'm trying to supply several sensors form photovoltaic panels and I need to limit the current but i don't know the simplest way to do it.
The panels give me a current between 22-38 voltage and power is 400 w this means the current is around 10 amps.
Can I limit the current for a value of 2 or 3 amps ?
If is possible what component should i use or what type of circuit?
PS:I know that the the solar cell should be connected through a battery but this is only in test purpose.
Best regards
Grogu
Joined Nov 30, 2016
9
Hello E,
As I told before it's in purpose test. And I want to use more or less the next ones:
http://es.farnell.com/linear-techno...f/current-sense-amp-200khz-5tsot23/dp/2294764
http://es.farnell.com/linear-technology/ltc2433-1pbf/ic-sm-adc-delta-sigma-16-bit/dp/1330933
http://es.farnell.com/linear-technology/lt1236bcs8-5-pbf/ref-de-tensi-n-serie-shunt-5v/dp/1273434
https://cdn-shop.adafruit.com/datasheets/ina219.pdf
http://www.robotshop.com/en/led-voltage-meter-blue.html
Arduino board.
I'll not put all of them but the idea is that i'll try to have and output of 30V and limiting the current at 2 amps
I'm trying to transform my house in a phone application. :)))
My idea is to connect them in parallel before the limiting device (or circuit).
Grogu
Joined Nov 30, 2016
9
Yes i know but that i had choose Current/Power monitor to be able to check any time the consumption of current.
I'm looking for another idea that exclude the fuse resistors.
Thanks a lot! :D
Grogu
Joined Nov 30, 2016
9
Hi!
Using the photovoltaic panel i'll have for sure a variation of voltage and current. My idea is use the power board that i put it in the link above and use an arduino board (arduino board support i2c comunication). And with all of them i want to see all the variation of the current and limiting of it went a situation of over current or a short circuit appear.
I all most finish my app in Android studio and with this to connect on internet via Ethernet and i want to see all this in my phone.
For me it's an interesting project an i want to finish in this way :)))
All the best
djsfantasi
Joined Apr 11, 2010
9,237
Hi!
All the best
OK! I was curious because many people enquire about limiting current, when there is no need for it.
ericgibbs
Joined Jan 29, 2010
21,439
hi G,
In normal operation, a circuit will only draw the current from the power supply that it requires to operate.
If you want to limit the current drawn in a short circuit condition you need to have preset the 'non destructive' current allowed, by using a current limiter or a current fold back limiter.
So you must know the allowed current limit, what do you expect that to be in your circuits.??
E
Grogu
Joined Nov 30, 2016
9
My expectation is to have a limitation at 2.5A
My idea is to limit at 2.2 or 2.5 and if a have a value bigger then 2.5 in the circuit to be able to close it.
Grogu
Joined Nov 30, 2016
9
As i told before is only for me and for my experience with electronics.
I find a board that is use in aerospace industry. They use o board to limit the current when they supply a satellite. it's and LCL (latching current limiter).
I was thinking that is what i'll try to use in a small scale. This is the board that inspire me.
Grogu
Joined Nov 30, 2016
9
hi,
There are lots of ready made IC's that would be suitable.
https://para.maximintegrated.com/en/search.mvp?fam=cl_usb_sw&hs=1
What you asking for is a 'foldback' current limiter, that will reduce the s/c current to a 'safe' value in short circuit state.
A simple current limiter would not be suitable.
Your application sounds a little unusual, are you expecting sensor failures.?
E
Thanks E
I think i will use a MAX14571. I think this will be enough for what i need.
Thanks again for your replays :D
