Can anyone tell me the current flow and which supply is sinking and which supply is sourcing in the following configuration
A 20 volt supply connected to a isolated DC to DC converter the + of the DC to DC converter connected to GND giving a -20 volt output on the - of the DC to DC converter output if you then connect a resistive load across the 20 volt supply and the -20 volt from the dv to DC converter which supply is sourcing and which supply is sinking and what direction is the current flowing
