Current control circuit power supply
potatofarmer
Joined Jan 7, 2022
12
I have a 5 VDC 60 amp power supply. I cannot control amps, is there a circuit I can make to go from zero amps up to about 20 amps. I have built a couple of circuits to no avail, can anyone help me or offer suggestions, I would certainly appreciate any help, Thank you
dendad
Joined Feb 20, 2016
4,642
Do you want a current limit facility, or be able to drive a set current into your load?
As it is, the amps will be a function of the load resistance.
A power supply can control the voltage (fixed voltage) OR the current (constant current) over variable load, but not both at the same time.
So, what are you actually trying to do?
What is the load?
potatofarmer
Joined Jan 7, 2022
12
What is the load?
Drive a set current into load, maintain constant current
35,291
It may be difficult to do that with a 5V supply.
Ohm's law applies. What is the resistance of your load?
20A @ 5V requires R = V / I = 5V / 20A = 0.25Ω
To have 0-20A from a 5V supply requires a load that is 0.25Ω max, i.e. it has to be almost a dead short.
35,291
LoeQCab this is exactly what I was looking for, I already got my 5 volts this looks like adjustable amps, I forgot to mention this is for a electrolysis solution will it still work, Thank you
You are very unlikely to get below 1Ω in electrolysis solution.
potatofarmer
Joined Jan 7, 2022
12
I have another supply now that does that 5 VDC & 70 amps both constant and adjustable, but this other supply is 5 VDC out constant amps run wild
35,291
Think Ohm's Law.
Just for example, suppose the resistance is 1Ω.
In order to supply 20A you would need a 20V supply.
If the resistancs is 10Ω, you would need a 200V supply in order to deliver 20A.
5V does not cut it.
potatofarmer
Joined Jan 7, 2022
12
Think Ohm's Law.
5V does not cut it.
On my one supply I have been running 5 VDC. 20 amps both constant, for 1 week tomorrow morning
LowQCab
Joined Nov 6, 2012
5,102
It will give complete control if your Load can actually pull more than ~10-Amps at 5-Volts.
Make the Current-Sense-Resistor 0.1-Ohms to try to get
the maximum Current possible with this type of Circuit.
If ~15 or so Amps is not enough, a Hall-Sensor-type Current-Sensor will be required,
but its not difficult to make that change.
potatofarmer
Joined Jan 7, 2022
12
Perhaps you are using a special electrolyte and size of tank that gives a very low resistance.
@L NaCL or KCL it does'nt matter both work well, I just wanted to put a control on this other supply, I did not realize it was that big of a problem, but live and learn
35,291
Resistance is given as
R = ρ x d / A
where R is resistance in ohms
ρ = resistivity in ohm-m
d = plate separation
A = plate area
The resistivity of saturated NaCl at 25°C is about 5 ohm-cm.
