Current consumption
BobTPH
Joined Jun 5, 2013
11,603
Once again, the TS is, in all likelihood, trying to solve a non-problem in a project when he has only a vague idea of what the project is.
Pinkyponky,
You will learn a lot more if you stop overthinking things and build some simple circuits, refining them as necessary.
Bob
pinkyponky
Joined Nov 28, 2019
373
Page 3 - Analogue input capacitance.
Only if you tell me the frequency of the amplifier output signal!
I={V_{out}}{2 \pi f C}
[Edit] apologies for taking three tries to get my TEX code right!
I did the calculations. But, may I know one thing is that how you evaluate the formula which is above. Moreover, Which do I need to be consider as a load current either Analog Input Leakage Current (according to datasheet in page 3) (OR) the value is calculating from the above formula? and also say why?.
Ian0
Joined Aug 7, 2020
13,207
Both (add them together).
Because they are out of phase the answer will be
I_{load}=\sqrt{i_{leakage}^2+({2 \pi V_{out} f C})^2}
At a guess the current into the capacitor will be much greater than the leakage current (so that the leakage current could be ignored), and the total current will be insignificant compared to the maximum output current from the amplifier (so that the entire current into the input of the A/D can be ignored)
pinkyponky
Joined Nov 28, 2019
373
Thank you Ian0.
pinkyponky
Joined Nov 28, 2019
373
Where, f=20khz, Vout=5V,
According to datasheet, Ileakage=1uA, C=90pf.
Therefore, Iload=57uA
So, Can we say that load of the amplifier/ADC current consumption is 57uA and it would be negligible.
Ian0
Joined Aug 7, 2020
13,207
I think so - Most amplifiers (you didn't specify what the amplifier was) would be capable of 57uA output current.
