Current booster/amplifier for OTA
raghu_ota
Joined Jul 6, 2018
I am designing an Operational Transconductance Amplifier whose maximum output current should be 15mA. Using Super Class AB amplifier, I was able to get a maximum output current of up to 2mA. The supply voltage is 5V. So to boost the output current, I need to cascade it with a current amplifier with a small gain. What would be the best way to do so? Can I get a current in mA range using CMOS current mirror technique? Or should I design another opamp and a mosfet/bjt at the output the boost the current?
You should start with showing us your schematic so we can recommend changes.
