current amplifier
33,192
Need some better specs than that.
What kind of voltages are needed (what is the impedance of the intended load)?
How fast does the current need to be able to change.
balaji selva
Joined Nov 29, 2013
20
200mA to a 500 ohm device at the o/p side.....
fastness of current change does not matter................
o/p open circuit voltage of 100V
Alec_t
Joined Sep 17, 2013
15,156
what type of mosfet
N-channel, with a voltage rating >100V and a low Rds(on), e.g. IRFP4668.
N.B the FET and load will have to dissipate up to 5W and 20W respectively, so both will need substantial heatsinks.
If the load has any inductive component a reverse-biased diode across it will be needed to protect the FET from voltage spikes.
