Cure for flickering led tubes ?
ericgibbs
Joined Jan 29, 2010
21,505
hi,
Some LED modules use a half wave rectifier drive, which if not well smoothed can cause a 25Hz flicker, which humans can 'see'.
Has the flicker always been there or has it started recently.?
E
Bordodynov
Joined May 20, 2015
3,431
This happens with a cheap LED power supply circuit. This scheme gives a pulsating current of LEDs. Flicker can have the frequency of the input voltage, and twice as high.
DrewStupid
Joined Nov 28, 2018
64
With much efford i opened the driver end. One cap was swolen. Repaced it and it was fine. Also think it is inferior components.
