Bordodynov
- Joined May 20, 2015
- 3,431
Thank You So much!
The change in frequency to 1 MHz. and the characteristics of the actual crystal.Thank You So much!
What is the design aspect behind selecting parallel capacitor C9 and C8, 20pF in this design and 100pF in the previous design? Also the C3 value?
How can I find out the total current draw and power consumption in this simulation? I mean from the output?
In a .tran (Transient Analysis), the waveform viewer will calculate the power drawn from a source and display it in a small dialog box.How can I find out the total current draw and power consumption in this simulation? I mean from the output?
THANK YOU SO MUCH!In a .tran (Transient Analysis), the waveform viewer will calculate the power drawn from a source and display it in a small dialog box.
You run the simulation, use the cursor to hover over the voltage source, press the "Alt" key and the current meter turns into a thermometer, a left click will give you the product of current and voltage. Control-left click on the trace name gets you the average power over the displayed interval.
