Crystal or oscillator for 48MHz circuit
Louise
Joined Jan 17, 2010
13
Hi! A quick question hoping for a quick answer . . . I need to provide 48MHz to facilitate clocking for my AT89C5131 USB interface project. I must admit almost complete ignorance regarding the difference between using an oscillator and a crystal. Can anyone point me in the right direction, please?
spinnaker
Joined Oct 29, 2009
7,830
An Xtal is a component of an osc. You can also have an RC osc too. Check your datasheet. Probably all you need to supply is the xtal and a couple of caps and a resistor.
GetDeviceInfo
Joined Jun 7, 2009
2,284
Unless you plan on using the 'clock' source for something else, a crystal, along with the required capacitors are sufficient.
You may want to ask yourself, should I use a crystal or a ceramic resonator, which is typically much smaller.
