Here they are sorry. I added the revision suggested by SgtWookie.
John
John
Hi John, can you share the original 555 crystal oscillator schematic with me? Thanks......FredDo you have an accurate frequency counter? I only built the circuit on a breadboard and fear that a real PCB design would require a different capacitance. As you know, the capacitance loading can pull the frequency in either direction. If too much, the freq will be slightly low; too little it will be high.
If you have a CMOS 555, it might be worth a try. Maybe I will try it after breakfast.
Edit: Breakfast will wait. Yes, the CMOS 555 works much better. It starts right up and has a nice square wave without the little hump. Uses same capacitance as the NE555 on the breadboard.
John
