Thank you for your reply. I don"t know where the DC fuses are located to check it as well as the teansistors to check in power supply.. I will download the diagram SirAre the outputs at a high DC level? If not, it probably has output relays, and the output before the relays are at a high DC level.
Has it blown one or other of the DC fuses?
If so it probably has a short-circuit output transistor or two.
With any luck, the damage has gone no further, and it will return to life after replacing the faulty ones.
Probably pcb mounted. Does it have a 50/60Hz transformer or a switched-mode? I’m assuming 50/60Hz. Look where the secondary wires connect to the pcb. You should see the bridge rectifier and smoothing capacitors. Look around that area for the rail fuses.Thank you for your reply. I don"t know where the DC fuses are located to check it as well as the teansistors to check in power supply.. I will download the diagram Sir
Thank you Sir. I will keep you posted as soon as I check the diagram or the main board itsefProbably pcb mounted. Does it have a 50/60Hz transformer or a switched-mode? I’m assuming 50/60Hz. Look where the secondary wires connect to the pcb. You should see the bridge rectifier and smoothing capacitors. Look around that area for the rail fuses.
Looks like a fixed frequency LLC resonant circuit to me. I like the way they combined the power supply for the drive to the top FET with the gate drive signal using a pulse transformer. Neat!Hello,
I can found an user manual.
Pages 17 and 18 show some troubleshooting.
I also found the schematics.
The powersection looks like an SMPS, see page 5 of the schematics.
Thank you so much SirHello,
Tips for that plain Weller 8200 soldering pistol... | General Electronics Chat | 41 | |
| G | Crown Xti2 2002 Locked in protection mode | Technical Repair | 34 |
