Crest CA12 problem (Clip LED)
seekude
Joined Oct 31, 2016
18
Hi! i got a problem with a Crest CA12 amplifier. This is the situation, the clip LED from one channel light on before the other channel (only when i increase the volume), same audio signal, i switch the preamp boards and the problem persist.
Kermit2
Joined Feb 5, 2010
4,159
Does it sound ok? Is it actually clipping or just the LED acting up? How can you tell?
We need more info. You need to do more basic troubleshooting to further isolate the problem.
Is that possible? Do you have any test equipment?
seekude
Joined Oct 31, 2016
18
Soundw right all the time, but when it reaches the clip (led on clipping) the sound decrease (limited by the circuit according the schmatics). I only have a multimeter in my hand right now, and the schematics.
Joined Nov 30, 2010
18,224
Look for a clipping level adjustment. If it doesn't exist, you're going to have to dig farther into the circuits.
seekude
Joined Oct 31, 2016
18
What i've found is a shorted diode (D44) but the problem is still there, i notice if i measure dc in the output (no input, pots at the lowest), in the good channel i have 0V and in the problematic channel -2.9mV.
Meet28
Joined Feb 7, 2019
i a also facing same fault in CA12 clip light of A channel is blinking on 70% volume on other hand B vhannrl is wotking ok on 100% volume ! Have you found its solution !
seekude
Joined Oct 31, 2016
18
Yes i've found it. There was a shorted diode d44, but the reason was 3 pnp power transistors shorted between C-E, i found it after a full check (removing one by one). I hope it can help you.
Meet28
Joined Feb 7, 2019
Ok, let me check i will inform you after checking ! Thanks for your support ! Do you have its schematic. Will you plz share it !
Meet28
Joined Feb 7, 2019
Hello, i got the point. In channel power board has IC LM311 was faulty, i changed it, nowbits ok ! I will upload pic. Thank you for your kind feedback.
