Credit Card Goopum
OBW0549
Joined Mar 2, 2015
3,565
Ever receive a credit card or other plastic card in the mail, and it's stuck to a cover letter with a small dab of clear, rubbery adhesive on the back? The stuff I'm talking about shows good adhesion but is easily removable from both the plastic card and the porous paper of the letter without leaving any residue; it's odorless; it stretches to many times its relaxed length; and it appears to have been applied as a liquid.
I thought perhaps it might be some sort of "hot-glue" product, but it's far more rubbery than any hot glue I've ever seen. I looked at Glue Dots, but the product description for those doesn't quite square with what I'm seeing. And its easy-release behavior leads me to believe it's not rubber cement, either.
Does anybody know what this goop is? I want some, as I can see some hobby uses for it as well as application in the grandkids' crafts.
Any ideas?
OBW0549
Joined Mar 2, 2015
3,565
3M Gummy Glue? Sounds like it.
Yeah, that sounds like the stuff. Found it on Amazon, but sold only in a case of 770 sticks for ≈$350. I'm not after sticking everything in the universe to everything else in the universe, though...
AKA Booger glue!!:p
Good name for it!
Thanks. Maybe I can find it elsewhere in smaller, more affordable lots.
Good name for it!
That stuff annoys my shredder.
You didn't say what you needed it for, but I really like this putty: https://www.scotchbrand.com/3M/en_U...oz-White/?N=4335+3294529207+3294602205&rt=rud
I use it over and over again and it has some impressive holding power.
MaxHeadRoom
Joined Jul 18, 2013
30,810
While on the subject of adhesives, I keep a fairly wide selection of various types in order to cover as many applications as possible.
But one, which evidently has been around since 1932 that I had never heard of until a few years ago, was Durhams Water putty.
Especially if working with wood, it has many multi-use advantages as an adhesive and a filler etc.
And Very cheap.
Growing up in the UK I had never heard of it there.
Max.
shortbus
Joined Sep 30, 2009
10,049
Do they still make that? Haven't seen it for a long time. Should have Googled before asking, they do still make it, but it seems like it's only available in big cans.
One of my great grandads was a cabinet maker and used it to fill nail and screw holes. He had some kind of color dyes he mixed in it to match the different wood tones.
djsfantasi
Joined Apr 11, 2010
9,237
And Very cheap.
Max.
An excellent product. A little known niche use for it, is in the manufacture of puppets. It’s properties are ideal for puppet heads, hands and feet.
