Creation of a sensor to play different sounds when triggered
Sarthak.Pahwa
Joined Jun 20, 2017
trying to create something which is shown in the above picture
sensors are the protruding circular things which on being triggered produce different sounds
can some one give me a direction on where to start
Picbuster
Joined Dec 2, 2013
1,059
Start producing a readable picture and describe exactly in detail what you want.
eq sound is meaningless should give frequency and number of dB needed ( dual or single tone)
eq sensors light/sound contact temperature moisture and much more
used power supply
operating variable safety
one off /pro/child/ medical.
Picbuster
Sarthak.Pahwa
Joined Jun 20, 2017
used power supply
Picbuster
Its not a single sound
its a sample
(.wav ) 16 bit 44.1KHz
contact sensors
power supply : Unknown
on off
Picbuster
Joined Dec 2, 2013
1,059
Take a vnc2 from ftdi. ( demp board (60$ or so)
put your sounds on an usb stick.
connect the sensors to the inputs
one output to a simple amplifier.
make a table sw1= x.wav sw2 = x2.wav and so on.
write a bit of code and off you go. ( 1/2 day)
picbuster
Sarthak.Pahwa
Joined Jun 20, 2017
picbuster
Where is the code to be written on??
I am really sorry
I am new to this
