Creating negative rail supply with op amps ?
Status
Not open for further replies.
MathematicianKing
Joined Nov 10, 2017
34
Hi there,
is it ok practice to generate negative voltage supplies using a simple op amp with neg feedback ?
If I have a single +ve supply and I need a -ve supply of some value, can I just build this opamp circuit to generate it?
I've seen solutions using diodes and caps but which is best ? Also using more elaborate circuits with opamps and such.
dl324
Joined Mar 30, 2015
18,524
An opamp can only produce voltages between it's V+ and V- supplies. Post a schematic of the circuit(s) you're referring to.
Best depends on current and voltage requirements.
MathematicianKing
Joined Nov 10, 2017
34
The voltage would be lower than V+.
Suppose the current requirements are satisfied by the opamp, is this a solution that is used by anyone ? Or this is just an unusual solution ? In other words, where does this fit in the ultra grand godly scheme of things?
35,321
As Dennis says, you can't get a negative voltage from the opamp if you don't have a negative supply.
(There are exceptions, of course. If you AC couple a signal it will go negative. You can also use a charge pump to create a negative voltage from a positive supply.)
If you must use a single supply opamp then you can create a pseudo-ground that is half-way between the supply rails.
OBW0549
Joined Mar 2, 2015
3,565
Please post a schematic diagram of this "solution" you're referring to; I can't make heads or tails out of what you're saying.
Op amps don't generate negative supply voltages; they use them, and can only create a negative output voltage if they're given a negative supply to operate from. As @dl324 said, an op amp can only output voltages lying between the supply voltages applied to its V+ and V- supply pins.
You seem to be operating under some misconception or other, though I can't figure out what it is...
MathematicianKing
Joined Nov 10, 2017
34
I have an LM358 here which operates from a single supply. Can I use this opamp in an inverting feedback config so as to generate a negative voltage that I could use as a negative rail in my circuit ? I don't have schematics or a circuit, it's something I want to know.
35,321
Why do you keep asking the same question even after we told you it would not work?
Here are your three options:
1) use a dual power supply
2) use a charge pump to generate a negative supply
3) use a pseudo-ground halfway between GND and the positive supply.
OBW0549
Joined Mar 2, 2015
3,565
No.
One more time: an op amp can only output voltages lying between the supply voltages applied to its V+ and V- supply pins. Period.
GopherT
Joined Nov 23, 2012
8,009
Read about the phrase "clipping". It means, even if your op amp has a gain of 1200, it won't output a 1200v signal for a 1v input. The output won't go more than supply voltage (for an op amp with rail to rail output). It won't go to more than 7 volts for a 9 v supply if you have a traditional op amp.
Also, just because you are configuring an inverting output, it won't generate a -1200 volt signal. It won't go below 0v on a single supply op amp (rail to rail) and it won't go below 2v for a traditional op amp. Understand?
35,321
<snipped abusive quote> JohnInTX
I am not confronting you. You have been told repeatedly that an opamp cannot generate a voltage beyond its power supply rails. It is simple as that. There is nothing special to understand.
GopherT
Joined Nov 23, 2012
8,009
<snip>
Anyways guys, it seems my problem is that I thought a +ve supply amp could go negative. Apparently not.
The problem is, you need to ask questions about the answer if you don't understand the answer. Please don't keep repeating the question until you get an agreeable answer because agreeable answers don't suddenly appear.
Mod edit: snipped abusive quote - JohnInTX
35,321
<snip>
For a new member, I am sorry to say you are off on the wrong track. This forum does not tolerate belligerent behavior, period.
ian field
Joined Oct 27, 2012
6,536
Hi there,
It can be pretty simple, you need an inverter (common usage puts "inverter" into an unrelated context). A lot of people use a 555 to drive a capacitor/diode charge pump, or there's the off the shelf 7660 chip. You can do it with a single transistor, inductor and a few various components, but its pretty much trial and error which can get a bit fiddly.
cmartinez
Joined Jan 17, 2007
8,896
<snip>
If you wish to generate a negative voltage using a single positive voltage source, then I suggest you take a look at page 9 of this datasheet..
OBW0549
Joined Mar 2, 2015
3,565
You seem to have gone impatient as you've gone older isn't it ? You shouldn't be trying to help beginners if you have no patience.
Ummm... I think it's you, not me, who has "gone impatient"; I've just been trying to patiently explain to you that you can't get something for nothing-- i.e., that an op amp can't output a negative voltage if it isn't provided with a negative supply voltage in the first place.
Don't believe me? Try it yourself: get an op amp, configure it as an inverting amplifier, power it from a single +V supply, and give the circuit a positive input. What output do you get? Try it.
MY OP AMP IS SINGLE SUPPLY
Yes, I know; I got that from your very first post. And, like the others here, I've been telling you that you CANNOT get an op amp to output a negative voltage given only a single, positive supply; yet you don't seem to want to accept that simple, obvious fact.
No comment.
Status
