creating a offset voltage on a inverting amplifier
djstar
Joined Jan 26, 2008
39
I am trying to create a audio amplifier that runs from a single supply. fundamentally i need to create a high gain amplifier of around 1900 Av with a bandwidth of 400 to 400KHz with a defined input impedance of 50K and i have to use 741 op amps the inpout signal is around 1mV-10mV.
Ive decided to create a LPF with one op amp and then connect it to a HPF through another opamp, which will give me the gain and bandwith.
as the signal coming in is +/- 1mv i want to create a 5V DC bias that the signal will ride on. however i'm struggling to get the amplifier to work.. i have attached two photos.one showing the amplifier with the non inverting pin ground, this gives a output signal of around 0.2V with the negative part of the signal clipping which is what i expect. when i set a dc voltage of 5V on the non inverting pin i get a flat response?
for the time being i have left of the Cap on the feedback resistor which would create the LPF.
BobTPH
Joined Jun 5, 2013
11,677
At 400KHz, the 741 has an open loop gain of 2.5. It is totally useless for what you are doing.
And why would a audio amplifier go up to 400KHz anyway?
Bob
#12
I was working on that yesterday. I came up with, "You will need 76 chips to do this". Then I doubted myself and erased it. :oops:
Thanks for being more succinct than I could manage that day.
