Hi.
I’m new here…still trying to find my way around…but thanks in advance for any support.
For the past couple years, I’ve been running wall mounted fire tablets for my home automation. I’ve made the install nice and clean by taking a qi micro usb receiver, cutting it half, ditching the coil end, and then wiring the little button micro usb end to a usb A that plugs into a power source hidden in a wall box. Ive attached a picture.
I’ve recently purchased a refurbished Samsung galaxy a7 lite that has a usb C port. I figured I’d do the same thing, but was a bit surprised when I opened up the qi receiver I bought. I found 3 wires, not 2 or 4 like I was expecting. Attached is a picture. Once I cut off the qi board and have only the wires, do you have any idea how to wire this 3 wire cable to a standard 2 wire usb A like I did before? I plan on using the power supply that came with the galaxy a7 if possible.
Thanks in advance!!
Thanks in advance!!
