Hey folks! I would like to get some feedback from you all about creating a pneumatic system for a movable platform.
I need to control the movement of this platform on rails by APPLYING/RELEASING pneumatic brakes.
The platform can move when compressed air is supplied to the clamping elements and is BRAKED when no air is supplied.
Air pressure 6-8 bars.
Piping diameter: Approx. 20 mm
For now I have thought of a solenoid valve that I could place in between the compressor wall outlet and the piping of the pneumatic brakes of the platform. The issue I am facing is that the pressure in the pipes after the solenoid valve closes is not released and hence, that wouldn't completely apply the brakes. I thought of a valve with one input (From compressor) and two outputs (01 to atmosphere and 01 brakes). That would close the input in BRAKED condition and connect the 2 Outputs to release the pressurized air in the circuit after the solenoid.
I would like to control this all by a wall mounted switch that BRAKES (meaning stops Airflow) when pressed and RELEASES BRAKES (opens solenoid valve) when not pressed.
Please suggest some ideas on it. Or maybe if there could be a simpler way to implement this. Thanks!
