Creating a circuit to linearly increase the input voltage as the output voltage increases.
Bod
Joined Sep 18, 2016
317
I bought this: https://www.amazon.com/KKmoon-Digital-Programmable-Constant-Step-down/dp/B0745C58S4
and this to go with it: https://www.amazon.co.uk/KKmoon-Communication-Interface-Constant-Converter/dp/B077NYLPNH
I have to say, they are great but have one major downside - you can't have an output voltage more that your input as there is no boost circuit. Take this: if I were to provide it with 12.22V exactly, I could pull out 11.22V at the max.
With this, I decided I should buy a boost converter and power it with 50V (the max) so I can have full use. However it recommends not to power it with that much as it can be damaged. Although this sounds like a strech, I don't want to risk it (and this also sounds like a fun project!).
My main idea for this is that:
I will provide it the boost converter with 12V (possibly 5 if I wanted to add another small fan.)
That means I can pull out 11V. When I am pulling out 11V, the circuit activates the boost converter and boosts it to 24V.
If I pull out 23V it will boost it to 48V - just under the max. This means it will only provide the right amount of voltage when needed.
That was my main idea, although, as I am writing this, it occured that I could be a linear change and that might be easier. As the output voltage increases by 1V / 2V , the input voltage increases by 1V / 2V.
Hope this makes sense, feel free to ask questions.
Bod
EDIT: I want to follow up on my second idea of the linear increase. I think it might be slightly easier.
38,813
I don't understand what you plan to use for an input power source, why you want a boost circuit, and why you want it variable. (?)
Unfortunately what you said, doesn't make much sense as you don't seem to understand how the module works. o_O
The input voltage should be a near constant DC at slightly above the maximum output voltage you will ever want (but below the max rating, of course).
The module will convert that to whatever output voltage you want by adjusting the output voltage setting.
It should do that with good efficiency, as it's a switching type supply.
dendad
Joined Feb 20, 2016
4,641
First, what are you going to power it from? If the mains, just get a transformer , bridge rectifier and filter cap to supply the voltage you need.
I don't see much advantage to adding a tracking boost converter to the front end. Although it would be an interesting project.
Sometimes a tracking pre regulator is used to limit the dissipation on linear regs but this is a switching one so that is not really needed.
A 12V 10A boost converter set to 32V could be used but just remember, the power loss and extra current the circuit will draw from the 12V voltage supply. Maybe an opto coupler with series resistor and zener wired across the KKMoon power supply could be used to detect the drop across it and the output of the opto coupler be used to set the voltage on the boost converter. But make sure you do not go over the max power supply input voltage. In fact, I would stay a few volts lower.
How does the 50V option work? Is is a board build option or a user selectable one? Or another model of the power supply?
Bod
Joined Sep 18, 2016
317
To clear this up. I am powering this with 12V. As I said in my post, that means I can get 11V out. However, I would like at least upto a 45V output, which means I’ll need an 45V power supply. Of course, I could take this 12V and boost it to 45V with a boost converter but as it states on the Amazon page, it isn’t recommended to provide it with this voltage as you are at risk of damaging it. This is where my idea of so called “tracking boost converter” came from. If it increases the input as the output voltage increases, it will only be at 45V for the time that you have the output set to 45V.
I don’t really get your question. There is no “50V option” - that is the maximum voltage you can provide on the input and the max you can get on the output.
Hopefully I cleared some confusion,
Bod
dendad
Joined Feb 20, 2016
4,641
I was just going by that on the web site.
You maybe able to use something like this..
https://www.amazon.com/Regulator-Ye...ost+converter&qid=1551738252&s=gateway&sr=8-6
And modify the voltage feedback sampling by adding the output transistor of an opoisolator as I mentioned before, or even a LDR driven by an LED with appropriate resistor and zener or series voltage reference chip so the LED starts to light as the volts across the main power supply gets above maybe 3 V.
Another way is to just have 2 steps of voltage. Boost the 12V to say 28V so yo can go from 0-24V in one range, then boost to 48V for above 24V.
That could be done with a voltage comparator on the main output that switches another resistor into the boos converter feedback look.
My analog power supply has a relay that switches the transformer secondary tap for more volts on the high part of the output range.
Bod
Joined Sep 18, 2016
317
Oh right, I missed that, sorry. I do recall there being 30V option as well.
That could be done with a voltage comparator on the main output that switches another resistor into the boost converter feedback look.
I will try that option out.
Also, what is the 'boost converter feedback loop' and is there one on the converter you provided? If not, will I have to make my own converter? (
Bod
38,813
Would that work?
Possibly.
But it would likely be better and simpler to use a chip dedicated to a boost regulator operation, such as the LT1070.
The LTspice simulation below shows the chip with an added op amp configured as a differential amp to provide for the external voltage input control from the module output.
Note that the LT1070 output (green trace) stays about 5V above the module output (Vadj, yellow trace) starting above about 9V for Vadj,
Is that what you wanted?
Bod
Joined Sep 18, 2016
317
I have successfully built it and it seems to work like the one shown:
Screen Shot 2019-03-06 at 17.08.29.png Screen Shot 2019-03-06 at 17.11.36.png
There are a couple things I still dont get though, would the output be Vadj? And also, what is making the voltage increase on LTspice?
Bod
EDIT: can I use a PWM signal to controll the output of this?
Bod
Joined Sep 18, 2016
317
Ok, I keep changing it but I could use a 555 timer boost converter as that would use PWM right?
Bod
38,813
Vadj is the output from your purchased module.
The simulated module voltage from V2.
I don't understand.
The LT1070 already is generating a PWM signal to control its output voltage.
To do the same function with a 555 requires a bunch of additional circuitry. Its PWM duty-cycle is not readily adjustable over a wide range using a voltage control, as is required here.
Bod
Joined Sep 18, 2016
317
Oh, right! That makes sense now. So I just provide it with a 12V supply, take the output of my module into 'Vadj' and use the wire labled 'OUT' to go into the input of my module.
If that is right, then that works just like I needed it!
It was just an idea.
Bod
38,813
That is right.
But I still see no significant advantage in doing that over just providing a fixed input voltage to the module, since the module already is a switching supply that uses PWM to efficiently control the output voltage.
Bod
Joined Sep 18, 2016
317
I agree to an extent - I have an arduino running at its maximum voltage and it has been fine for many months. But for the sake of it being my only power supply, I would like to be on the safe side of things (I also just really like making things complicated for myself)
Anyway, thanks for the help, it is much appreciated.
Bod
