Creating a circuit from the waveform.
moonlystar1111
Joined Feb 1, 2024
106
signal can be inverted using another opamp or comparator or a transistor..
step 1 accomplished - you got a working oscillator.
step 2 duplicate it to get second oscillator that runs at higher frequency
step 3 buffer or invert signal as needed
step 4 combine signals...
step 5 ...
step 10 see if things could be optimized / simplified
Hey.. I cant find the next reply ...
ericgibbs
Joined Jan 29, 2010
21,506
Hi 1111.
It is an AAC ruling that we do not give final/complete answers to marked Homework or College assignments.
We can only give help and guidance.
Moderation.
moonlystar1111
Joined Feb 1, 2024
106
Hi 1111.
Moderation.
Okay.. actually it was not final homework answer.. it was almost 10th part of my work.. BTW I'm really thankfull for the guidance..
moonlystar1111
Joined Feb 1, 2024
106
Hi 1111.
Moderation.
So.. was that reply got deleted automatically..or someone deleted it.. just curious to know cuz I'm new in AAC.
moonlystar1111
Joined Feb 1, 2024
106
step 5 ...
I tried and draw a schematic including 2 oscillators. But in the second oscillator, capacitor c2 is charging and discharging when capacitor c1 is discharging. I want to make it opposite. I want to make cap c2 charge and discharge when c1 is charging..
I have attached my schematic below.
moonlystar1111
Joined Feb 1, 2024
106
I want yo design a circuit where when a capacitor is charging and above a given threshold, the output will be pulse train and when it is below reference voltage tye output will be low. I have attached a handwritten expected waveform below. I tried to make it using ltspice which I have attached. But my output comes out to be opposite of what I expected.
The schematic includes 2 oscillators. In the second oscillator, capacitor c2 is charging and discharging when capacitor c1 is discharging. I want to make it opposite. I want to make cap c2 charge and discharge when c1 is charging..20240220_154611.jpg
LesJones
Joined Jan 8, 2017
4,509
Have you thought of using a comparator in place of Q1 ? You could even connect one input of this comparator to the top of C1 (triangular wave form.) and connect the other input to a variable voltage which would let you adjust the duty cycle of the square wave on it's output. This would allow you to control how many pulses were in each group.
Les.
