Hey all, hoping someone can push me in the right direction. This amp is broken up into 4 boards, Power Supply, Amp, and 2 preamp boards. I was able to get the schematic from Crate so bonus there!!
Symptom: Blows main Power Supply fuse when switched on.
I disconnected the power supply put a fresh fuse in and I get the expected -45/+45Volts DC out, so the PS is good at least with no load it's good. Next I connected the Amp but not the preamp and that blows the fuse when turned on, so I'm thinking something in the Amp is most likely. Nothing visual and I've gone through and check resistance values to make sure nothing is shorted to gnd etc. That is pretty much where I'm stuck, without being able to put voltage to the board does anyone have suggestions? I've attached the schematic
