Counting losses using 74LS93
dl324
Joined Mar 30, 2015
18,473
I recall learning how to create some relatively simple macros that at least could result annoying if not dangerous.
A .docx can't have macros. If you try to rename a .docm, which can have macros, to .docx, Word won't load it. At least that's the behavior with Excel files.
dl324
Joined Mar 30, 2015
18,473
anyone have any ideas on how i can solve this? i have tried using timing of the outputs but this was unsuccessful
Did you change anything in your latest schematic; aside from adding the second display?
Your style is very messy and that makes it more tedious to follow the flow of the logic...
ericgibbs
Joined Jan 29, 2010
21,577
Start a new thread get it out of homework and I'll give you the answers!
hi D,
Thats not in the spirit of AAC.
Why cannot you help him with his Homework problem, if you have a means to guide him to the answer.?
E
abrar.haque
Joined Feb 23, 2021
12
I havent as of yet as it has been based on trial and error. apologies for the drawing style i will improve this for the future
DickCappels
Joined Aug 21, 2008
10,661
Solving problems in electronics by trial and error beyond one or two simple variables (like resistor values) can result in a very long debug session and a less-than-optimum solution.
I tell you from experience.
