Hi guys.
Im new to assembly programming.
I want to do a countdown timer using AT89S51.
So,i need u guys help.
Here how the hardware goes:
1)Double 7 segment to show the countdown time.
2)A buzzer that will beep once a second from the countdown starts till ends.
3)A switch to start the timer and a switch to Reset the timer.
4)2 switch to set the duration(A switch for x10 increment and a switch for x1 increment)
5)A switch to select between minutes and seconds.
6)2 outputs to relays.
7)An indicator to show minutes or seconds(LED or 7 segment)
And if possible,i want the timer or the 7 segment to go to the sleep mode after the countdown ends.All switches is push button type.
I dont know how to write the program in ASM.So anyone can help me with the programming?
