7 segments as Countdown timer that isn't using any microcontroller or microprocessors
Phezel
Joined Nov 26, 2021
Hi, my professor assigned me to do a project that must use 7 segments as Countdown timer that if it goes 0 then the bulb must be off but if my pir sensor detects a movement even if it starts counting down, it should be restart again . He said I shouldn't use microprocessor or microcontroller to do that, what components should I use and the schematic for it?
djsfantasi
Joined Apr 11, 2010
9,237
First, this is Homework Help. You must do the work and we can help direct you. Supplying a schematic is out of the question.
You’ve missed some information. Like count down from what?
Which components do you plan to use? You’ll need a clock and a counter…
