Could someone identify this part?
ieronim
Joined Aug 30, 2017
Hi, could anyone please help me identify this part? It's from the power section of a laptop main board. Could be a DC-DC converter or switching regulator. I can't even figure out whose logo that is...
Many thanks
ian field
Joined Oct 27, 2012
6,536
Might be Siliconix or something like that
Many thanks
Siliconix looks the nearest match on the image wayneh linked.
As a totally wild guess - maybe a MOSFET, could be a dual.
ieronim
Joined Aug 30, 2017
You're right, thank you. It is a Siliconics / Vishay MOSFET!. Problem is, there's no reference to this particular part number, so I dropped them an email and have yet to hear from them. Wish I knew at least if it was P-channel or N-channel...
ian field
Joined Oct 27, 2012
6,536
There's usually an omitted alphabetic prefix - sometimes you have to make an educated guess before their search bar can find it.
There are various types, but pin layout has a limited number of permutations. As long as the part isn't blown - you can try the various pin identifications for a few basic tests.
If you can identify gate and source; short them together - this turns off the channel so you can only measure the intrinsic body diode. which way its pointing tells you the channel polarity.
