could someone have a look at this constant power circuit
nathansmith2611
Joined Sep 24, 2018
6
The circuit attaches onto an ardunio uno which will be programmed to control the digital potentiometer which will change the voltage going into the motor threw a buck converter, the motor is shunted to mesure the current passing threw it.
The circuit is meant for a small car that has a small power source and I needed as much power as I could get.
Alec_t
Joined Sep 17, 2013
15,167
Controlling a motor by varying its supply voltage is not usually the best way, because the speed will vary according to the load. PWM is a more efficient method, with the duty cycle varied to maintain a desired speed if required.
