Correct AC motor for turning sculpture
28,235
Half inch will work very well, quarter inch would be adequate for that application, but less forgiving to work with. The stuff I am thinking of is also used for lining chutes that metal parts and chips fall through in industrial machinery. What is handy is that you can machine it with woodworking tools. It is also referred to as UHMW, (ultra high molecular weight PE) Ordinary PE is not as tough, but it could work in this application.
mxabeles
Joined Apr 25, 2009
295
The sheet of plastic (its a cutting board made with the material you described) and the pillow blocks were delivered same day, and it was simpler to just bolt the flange onto the top of box and test. It worked! As a first attempt I'm happy. The motor itself is not level because I was just eyeballing everything, thus the pole is at an angle. But it's surely turning with ease and as a proof of concept I can claim it as a success. Thanks again!
28,235
Now I am wondering about the actual speed that the motor and the sculpture are turning. One more thought is that with the sculpture being a very light load, that you might possibly get away with longer operating times. .
So you could run the motor for a few minutes and feel the electrical portion of the motor after switching it off. If it has not become hot, try it for ten minutes and see. The one-minute time may be for the full load rating.
shortbus
Joined Sep 30, 2009
10,049
Your much better off with the pillow blocks instead of a part made of plastic. The plastic will not do anything to support the weight of your sculpture. The pillow blocks while working for rotation also have a good deal of thrust(the weight of your sculpture downward) handling capability. There is no thrust capability to a piece of plastic with a hole in it.
shortbus
Joined Sep 30, 2009
10,049
@mxabeles Another thought. since you have a female 1/2"NPT in the bottom of the sculpture and that doesn't match up to any pillow block inch or metirc, you could get a 1/2"NPT bushing and drill out the pipe thread in the bushing to make a standard size rod instead of the pipe. that way you don't need to mess around trying to make a pipe work in the pillow blocks.
A pipe bushing like this -
And drill the center to fit rod.
28,235
Certainly a UHMWPE sleeve bearing does not normally offer any axial support, while a correctly implemented pillow block bearing CAN provide a great deal of axial load support. But that will only happen if the rotating shaft is adequately tied to the bearing in the block. To adequately support this pipe shaft for both the axial load and the side load will take a correctly machined spacer or an correctly shaped wedge collar. Making ay of those parts will require a lathe, a tool, and a fair amount of skill. Or an additive printer able to print steel or a suitable alternative material, as well as the skill to create the build file. Neither of these are common among the general population.
shortbus
Joined Sep 30, 2009
10,049
So then your saying it's better to make a plastic plate type bearing, one that will float and not support the pipe shaft, instead of using pillow blocks? If making the shaft fit the pillow block correctly is too hard, how hard is it to make a hole of the correct size in the plastic? A hole that doesn't correspond to any, known by me, drill diameter. And that plastic will give no axial/thrust support what so ever to the shaft.
28,235
NO!!! I am NOT saying it is better. I am describing the difference.. Neither scheme will be simple.
IF the connection to the motor was adequate and IF the motor shaft and the motor bearing could handle the end load of the sculpture weight THEN there would be a simple choice.
Unfortunately we don't have much of an idea as to any of those answers. A pair of pillow blocks, one above the surface and one below, using the same bolts, and adequately aligned, should hold that sculpture steady. If that arrangement could handle the total load, then the coupling could be much simpler.
So if the bore of the two blocks is 1.00 inches and the diameter of the pipe is 0.84 inches then the adapter sleeve to allow a snug fir will be 0.08 inches thick.
Do the pillow blocks have setscrews?
mxabeles
Joined Apr 25, 2009
295
Great conversation. And very grateful. I was away in DC for the weekend, so I just was able to peruse the thread now. The pillow block does have set screws. That's the only way this works XD.
28,235
If the two set screws and the required shims are correctly adjusted then there would be very little off-center movement of the pipe. At that condition the coupling can be as simple as a cross-pin toward the end of the motor shaft and a pair of notches at the end of the pipe to sit on the pin.
Or, if the end of the pipe is threaded, use a simple pipe coupling to attach what is often called a cord grip, or even a "Greenfield" adapter, which can simply tighten onto the shaft. No machining or drilling required. That sort of connection is on lt suitable for low speeds and not much torque.
There is another question: How is that motor-gearbox assembly working out? How hot does the motor get with constant operation at the low speed?
mxabeles
Joined Apr 25, 2009
295
Thanks for the reply. I don't have the motor running constantly, I plan to have SSR relay + Arduino controlling the power to motor.
28,235
Consider the loading on this bearing relative to the bearing specifications. The axial load is about 35 pounds, and the radial load might be ten pounds. And the present bearing blocks are for one inch shafting. So the safety factor is about 100:1, probably better than that.
Next, consider the rotating speed, which is, I think, about 10 RPM.. The bearing max RPM for long life is 3000 RPM.
So for this application these bearings are far more than needed.
And finally consider that the TS is an artist, not a machinist.
So the heavy pillow blocks allow rugged mounting with reasonable bolts and if they are not tight enough it will not matter. AND those materials are already in hand. Tapered roller bearings are great for wheels in cars, that is certain. This application is not so demanding. Nor does it have an unlimited budget.
mxabeles
Joined Apr 25, 2009
295
