Yes, this really has to do with microcontrollers, and I will post code to prove it.
I am working on a digital cooking thermometer, which will primarily be used for roasts and such. Frying is easy to tell by touch. In another thread, I have shown some of my attempts to produce a graphical display. That work is pretty well along. I can scroll both the Y-axis (temperature from 40 to 295°F) and X-axis, which is basically unlimited. Data are put into and retrieved from a circular FIFO buffer and plotted. Code (draft) for that section is attached.
I like line graphs; however, in thinking about the end users (my adult daughters), I think something a little more colorful and graphic would be more useful. My favorite on-line cooking program is this (from MIT): http://up.csail.mit.edu/science-of-cooking/home-screen.html
If you want to test, enter these values:
It is pretty accurate. My TG rib roast was about 10 cm thick (3.5#) and took 1:20 to get to 126°F. I should have taken it out a little sooner, as it (like always) continued to cook on the counter. It was "medium rare" in the middle few inches. What I would like to show is a cross-section with the cooking zones moving inward as the temperature changes. That part should be relatively easy graphics.
What I need help on are the calculations done in the MIT link. Is anyone familiar with them?
As a last resort, I will contact the senior authors, but I don't expect that to be too productive, particularly for adaptation to a small MCU.
The following code snippet is for a PIC16F1829 at 32 MHz. The GLCD is 132x65 and uses an ST7567 controller. It scrolls as described above. I would like to thank member Mike McLaren for the original FIFO routine that was modified to fit this purpose.
Code:
;12/01/19
PutTemp0 ;called with new value in temp0
#define offsetY 2 ;"1"does not work well, used up to 10 in testing
#define offsetX 59 ;use 59...?, 40 used in testing
Validate_Y ;must do subtraction as increment may be >1
movlw 50 ;temp range of graph is 50°
addwf offsetF,w ;offsetF is subtracted from value to make in range
subwf temp0,w ;preserve temp0
btfss STATUS,0
bra Validate_X ;check X is (50+offsetF)>temp0 (zero/borrow clear)
movlw offsetY ;offset if (50+offsetF)<=temp0(zero set)
addwf offsetF,f ;increase offset by 10, affects all STATUS bits
bsf STATUS,0 ;count1 (no change)if this is only adjustment,
;now check X,set C to indicate need for FIFO adjustment - clears with addwf
Validate_X
incf count1,f ;
movlw 60 ;
xorwf count1,w ;count1 = 60, preserve count1
btfsc STATUS,2 ;
bra AdjCount
btfss STATUS,0
bra Continue ;no adjustment needed
bra FIFO_offset
AdjCount
movlw offsetX ;count1=60, reset to offsetX
movwf count1 ;
bra FIFO_offset ;count1 = 60, offset X, reset count1 to 0
FIFO_offset ;works around the corner
call LngDly
call ClrGraph
movf count1,w
subwf bufpull,w
btfss STATUS,0
andlw bufsize-1 ;turns corner
movwf bufpull
Continue
movf temp0,w ;PutGraph = movwf tempF, will change but not now
call PutFIFO ;
_Continue
DelayCy (10*msecs) ;2 ms is very quick
call GetFIFO ;temp0 has been added to FIFO and returns in WREG
btfsc STATUS,0 ;keep getting FIFO until buffer empty (STATUS,0 set)
bra _FillData ;FIFO buffer empty, get new value
call PutGraph ;PutGraph still uses tempF, so move temp0 to tempF
bra _Continue ;
Loop4evr
nop
bra $-1
;This is a stand alone version of M McLaren's FIFO.
FIFO
#define bufsize 64 ;64 ;bufsize = 2^n = 2,4,8,16,32,64,128
#define bufstart 0x2040 ;
clrf bufpull
clrf bufpush
; bra Test
FIFOLoop
addlw low(bufstart) ;w == bufpull or bufpush |B?
movwf FSR1L ; |B?
movlw high(bufstart) ; |B?
movwf FSR1H ; |B?
return ; |B?
GetFIFO
;Check buffer MT
movf bufpull,W ;push == pull (buffer empty)? |B0
xorwf bufpush,W ; " |B0
bsf STATUS,0 ;set "buffer empty flag", if needed |B0
btfsc STATUS,2 ;no, skip & process char, else |B0
return ;return w/ buffer empty flag set |B0
;Not necessary to clear buffer MT flag as 'addlw' in loop does that
;Character available:
movf bufpull,w
call FIFOLoop ;sets FSRn to bufpull location
incf bufpull,W ; |B0
andlw bufsize-1 ;wreg == ++bufpull % bufsize (wrap) |B0
movwf bufpull ;update bufpull pointer |B0
movf INDF1,W ;WREG to be processed |B0
return ; |B0
PutFIFO
movf bufpush,w ; |B0
call FIFOLoop ; |B0
movf temp0,w ;retieve new value |B0
;application specific probably change "put" to temp0 or temp1 comes
;from test generator (below) for simulation
movwf INDF1 ;add new value to buffer |B0
incf bufpush,w ;adjust pointer to new TOS |B0
andlw bufsize-1 ;wreg == ++bufpush % bufsize (wrap) |B0
movwf bufpush ;update bufpush pointer |B0
return ; |B0
