conveyor traffic cop
bwhept
Joined Apr 12, 2018
I need to use relays and/or timers to build a control box for two product conveyors merging into one. There are pneumatic stops on each lane that will help in the switching. Help!?
cmartinez
Joined Jan 17, 2007
8,841
You need to provide far more information than that
Why timers? Why not use sensors instead?
What do you wish to accomplish? Separate products into types? Join products from two different production schedules?
Try to use as much detail as possible in your explanation.
BR-549
Joined Sep 22, 2013
4,928
It's all gona depend on whether you drive on the left side or the right side.
Seriously.......you need to explain a lot more details. We are not mind readers.
MaxHeadRoom
Joined Jul 18, 2013
30,772
You most likely could do it with a Smart Relay, it has timers and counters. Plus I/O etc.
If not large enough then a small PLC.
This is typically how it is done now in Industrial control.
Max.
bwhept
Joined Apr 12, 2018
I originally planned on a smart relay, but then I was informed the machine has to run tomorrow, and getting one here today is impossible. I did figure out how to do it with relays and a timer though. Thanks for your willingness to help.
