Converting super short button press into longer input signal
38,772
are there any down sides to this method, or advantages to using the multivibrator that I'm not seeing?
One difference is that the multivibrator is likely more stable and accurate in its one-shot timing. It also can operate down to a lower voltage (1V).
The inverter can operate up to a 15V supply voltage, but that's apparently not an issue here.
It also has some spare inverters, if you need them.
