This is a part of my circuit, the coil of the relay is energized when a certain condition (e.g. monitoring voltage) is met and disconnects the battery from the load. The NO of the relay is connected to the base of the transistor so that the relay remains latched. The NC Push button is used to reset the relay.
Problem
The problem is that I don't have an NC Push Button (not available in stores near me) but rather have a NO one. Kindly suggest me a circuit to use this NO Push Button along with a transistor or some other components to get the same functionality of NC Push Button.
Problem
