converting LTSPICE Bxxx sources to PSPICE code
ron111
Joined Feb 24, 2018
I need to port a model to PSPICE, specifically these three commands for B sources
* if/then/else voltage source
B1 pwm 0 V=if((V(VIN,CMN_IN)+1-V(carrier_ramp))>0 , 1, 0)
*voltage source: multiply a node voltage by a parameter
B2 VOUT_P CMN_POUT V={V_OUT*V(pwm_p3)}
*voltage source: delay node voltage by a specified amount of time
B1 N002 0 V=delay(V(out),TPULSE)
eetech00
Joined Jun 8, 2013
4,724
Hi
I've successfully converted a few from Pspice to LTspice, but not the other way.
I believe the first one would be converted to this:
E1 pwm 0 VALUE={ if((V(VIN,CMN_IN)+1-V(carrier_ramp))>0 , 1, 0) }
The "IF" conditional expression syntax is the same for both simulators.
The other two statements would be converted the same way.
E2 VOUT_P CMN_POUT VALUE={ {V_OUT*V(pwm_p3)} }
E3 N002 0 VALUE={ delay(V(out),TPULSE) }
Pay close attention to whether the B source is for current or for voltage. For current, use a Pspice G source.
eT
