Im trying to upgrade my ps3 controller with a analogue trigger form a xbox 360
(It is installed and working)
The pressure sensitive buttons in the ds3 controller seem to be a type of switched earth.
(not sure if the wire in the ps3 'button mat' i am using is a 'true' earth though)
the resistance is reduced when the trigger is pressed.
So i have the xbox trigger all set up, (xbox triggers use a linear pot)
And i just connected the ps3 'wire' through two pins of the pot.
Unfortunately this gives a very non linear result. (still better than the abysmal ps3 setup though)
There must be a way to set the pot up to provide a linear response...
Unfortunately I don't know what to search for to get some ideas on this...
This is the original setup, and the current setup... Is there a way to get a more linear response from this pot?
Some crappy photos of the controller:
