Converting Dry Battery UPS to Wet Battery UPS
pakilahori81
Joined Apr 14, 2010
7
Hi All,
I want to convert my dry battery ups to charge wet battery. Please give me any suggestion how I can do this.
I replaced dry battery about twice but it did't gives any backup (Even of a second).
I can post ups circuit snapshots if you required to assist.
Thanks
Wendy
Joined Mar 24, 2008
23,830
Feedback and Suggestions Forum for providing feedback and suggestions about All About Circuits, including corrections to the e-book. This forum is not for getting help with technical questions.
A mod will be along presently to move this thread to a better area.
OK, so what is your dry battery? Part numbers are good, so are pictures.
pakilahori81
Joined Apr 14, 2010
7
Thanks Bill for your reply.
It's not of APC or other international brand ups. It's a local company product.
Battery is made by CSB. GP1272 12V 7.2Ah
Thanks
SgtWookie
Joined Jul 17, 2007
22,230
The CSB GP1272 is not a "dry cell", it is a SLA (sealed lead-acid) battery.
Manufacturer's page for the GP1272:
http://www.csb-battery.com/english/01_product/02_detail.php?fid=5&pid=11
You will need to compare that cell's specifications to the battery you will be replacing it with.
[eta]
It is common for SLA batteries to have higher float and charge voltages than lead-acid batteries.
You need a deep-cycle type battery. An automotive-type battery will have a very short service life. They are not designed to be used in deep-cycle applications.
Note that SLA batteries are safe for indoor use. More traditional lead-acid batteries (like automotive and marine batteries) are NOT safe for indoor use, due to the presence of explosive gases.
If your UPS provides no backup power at all, then either you are overloading the output, or the UPS is defective.
Don't try to power a motor (such as a refrigerator, washing machine, vacuum cleaner, etc) from a UPS, as the initial inrush current will be many times the rated power of the device.
retched
Joined Dec 5, 2009
5,207
Are you getting measureable output on the outlets of the UPS? If you have a lamp plugged in and you un-plug the UPS from the wall, does the lamp stay lit?
SgtWookie
Joined Jul 17, 2007
22,230
Lamps are also a problem, as they will have a very high inrush current until the filament comes up to temperature. It's one thing if the lamp is already hot and the power fails; the UPS should be able to continue the existing current flow if it's within the UPS VA rating. However, attempting a "cold start" on a lamp or motor will probably fail.
Wendy
Joined Mar 24, 2008
23,830
I find I have to replace my UPS battery every 2 years give or take. It uses a SLA battery. This is considered normal maintenance for a UPS.
pakilahori81
Joined Apr 14, 2010
7
Thanks for all of you guyz for your replies.....
But my concern is to convert that UPS to charge wet battery.
Can I directly use it's Live and Negative to charge battery or need any modification ?
My UPS detail is :
Alfa 5303
Input : 220/50 Hz
Output : 220/50 Hz
Capacity : 500VA
I have also attached images. Please help me to convert it. Thanks
retched
Joined Dec 5, 2009
5,207
Is the battery a 12v battery? If so, you can replace it with a regular lead-acid battery. It will charge it.
The problem is not in charging the battery. The problem is in USING the battery once you have it charged. If you try to start powering more devices, the UPS cant handle too much more current. The parts will heat up and blow.
If you just want more run time out of it, just switch the battery to your "wet cell". You will want to add a high flow vent fan to the case to ensure it stays cool. These UPS systems are not designed to run for an hour. They are built to get you time to turn the computer off without loosing any work. So if you run it longer than intended, you NEED to cool it.
retched
Joined Dec 5, 2009
5,207
Make sure the fan is blowing on the heatsink, and there is enough holes for the air to escape.
You may end up damaging your UPS if you run it to hard or too long.
pakilahori81
Joined Apr 14, 2010
7
Before I only used it just to shutdown my system or to run a light of 15watt light. What I come to know from your post is that I did't need to make any modification yo UPS circuit to charge Wet battery (Car Battery). Actually know I want to use it to lid lights of 15Watt.
retched
Joined Dec 5, 2009
5,207
you could. If you are going to run it for extended times, You will want to add a fan. A simple computer fan will do. And it can run off the 12v battery.
SgtWookie
Joined Jul 17, 2007
22,230
If the old car battery is still good, it won't be after a few cycles.
You must not use the car battery indoors, as you may have a build-up of explosive gases.
