Converting dc to single phase ac
sunnsa
Joined Sep 10, 2022
15
Or a boost coverter.
I recently did a 7kW emergency lighting system with 216V DC (18 x 12V 100AH batteries) using LED lamps with electronic ballasts. It switches from 230V AC to 216V DC when the mains fails.
@Ian0 may I know how exactly it works?
Ian0
Joined Aug 7, 2020
13,268
Afraid not - commercially sensitive information.
In principle - when the mains voltage is below a certain threshold a double pole contactor changes state and connects the lamps to the battery instead of the mains.
BobTPH
Joined Jun 5, 2013
11,643
Forget about producing the AC input. That would be going through two conversations each with losses.
Measure the DC voltage going to the LEDs when powered by the constant current driver, then buy a 12V powered 350mA LED driver that includes that voltage in it’s range.
12W at 350 mA suggests that voltage is 34V, but I would measure it to be sure.
Irving
Joined Jan 30, 2016
5,195
Thank you @Irving - however, the wattage of the entire light fixture is 12W, and I thought there will be a 12V input to the LED, so the current drawn will be 1A. For 8 hours of usage, I will require one 8Ah battery. Am I correct? And from the batteries, is it possible to connect two wires to a small dc-ac converter, at the other end of which I feed my LED wires? Kindly advise.
A 12W LED fixture comprises a number of LED that typically require 3 - 4v at 120mA. If your AC block is 350mA then you will have 3 strings of 8 LEDs, needing typically 36v.
To power these from DC for 8h you will need 0.35 x 8 = 2.8Ah @ 36v so realistically 4Ah or more depending on battery chemistry eg 3 x 12v lead-acid (SLA) will be 42v fully charged but only 33v at 20% charge so you wont get more than 70% discharge before the voltage drops too low.
This is why a boost converter running of a nominal 12v (9 - 15v) supply is a better solution than multiple batteries, but since your input voltage is 1/3 your current will be 3x and as the boost converter is only 85% efficient across the voltage range you need a little more Ah, about 20% more, so 12v 10 -12Ah again depending on chemistry.
Boggart
Joined Jan 31, 2022
82
This. Don't mess with higher voltage batteries, buck drivers etc, you want a single stage of energy conversion, from 12V to the LEDs' required voltage and current. Best bet for that is a Meanwell LDH-45A-350W boost driver, 9-18V input, 12 to 86VDC @350mA output at up to 95% efficiency. Readily available from many suppliers including Mouser for under US$20.
Boggart
Joined Jan 31, 2022
82
Here is an example of a driver that would run your LEDs from a 12V battery at 350 mA constant current. This would replace the AC power supply.
LED driver
Won't work for his application, he has 12W of 350mA LEDs, so around 12 in series, so needs a driver capable of 36V. The driver you linked to is a buck driver, so batt voltage would have to be higher than 40V (the driver has a 4V overhead requirement). The Meanwell driver I mentioned is the simplest, most effective solution for running a string of 1W LEDs on a 12V supply.
300-3056
Joined Sep 9, 2022
26
The old rotary inverters were interesting, but not overly efficient, and certainly not what the OP is looking for. They are a novel device though, used to have one many, many (many) years ago.
Ya I just wanted to see if anyone knew what it was.
I'm impressed.
BobTPH
Joined Jun 5, 2013
11,643
Yep, I missed that fact.
sunnsa
Joined Sep 10, 2022
15
@Ian0 - thank you, you mean it works like a UPS
sunnsa
Joined Sep 10, 2022
15
@Boggart thank you for the suggestion - I would like it to be powered from the ac supply also, at times, and from the battery, when the supply is not available. If we connect such a driver to the leads, I won't be able to run it on ac later, will I ?
sunnsa
Joined Sep 10, 2022
15
Th
Thank you @Irving for your explanation.
Irving
Joined Jan 30, 2016
5,195
Not without some additional circuitry, which could easily be incorporated into the charging arrangement. Basically something to sense when the AC is lost and switch to batteries. There are many options for this.
Ian0
Joined Aug 7, 2020
13,268
The simplest being a DPDT relay with a 230V AC coil.
Boggart
Joined Jan 31, 2022
82
If I were doing it, to keep all voltages safe, then I would run it from the battery and use a 12V, 1A (or greater) power supply to trip a 12V relay, which would feed 12V to the meanwell driver. When the power went out, the relay would drop out and change power sources to the battery.
Or, even simpler, have the battery permanently on float charge from the power supply, using a 13.6V power supply (some supplies have trimpots to adjust the voltage somewhat), and when power goes out, the supply simply stops supplying power and the battery takes over. You have to charge the battery anyway, so why not let a single power supply do everything?
It sounds crude, but the power supply will most likely have internal diodes that prevent the battery backfeeding the supply circuitry, but if that concerns you, as mentioned already, just include a suitable schottky diode between the power supply and battery.
I actually have a home built UPS that works this way, it has been running for quite a few years and works perfectly.
