Converting an Powersupply to a Lower voltage charger
hardusb
Joined Apr 20, 2020
18
I have an Wahl hair clipper to which I lost the charger, I am trying to build / convert an existing power supply to charger it:
It requires 3.5v 1A to charge, I followed some other guide on the internet to reduce the voltage of an 12v 2A Ac Adapter to the required voltage.
The device picks up the power input and shows its charging but I left it through the night and it didnt charge 1% even.
I measured the voltage while on charge with this circuit and it dropped 1V while charging to about 2.5v, not sure if its normal, I dont have any fancy measurement tools to use, only a basic multi meter.
Is there some other components needed to charge a device?
I did a little circuit diagram to illustrate what I did to accomplish this, this is all the components I had available at the moment.
I connected my device to charge on the bottom points.
ericgibbs
Joined Jan 29, 2010
21,567
hi h,
Welcome to AAC,
That circuit is totally unsuitable as a charger.
Do you have a old mobile phone charger on the bench you could modify.?
E
hardusb
Joined Apr 20, 2020
18
Just use any mobile phone charger, cut the plug off and solder it .
The device says it requires 3.5v 1A input and in clear writing to Only use the provided charger, so I wanted to get the same voltage at least of the original charger.
I opened up the device to see which battery it uses and its an 2.4V 1200mAh. 2 Long sells wrapped in green.
dendad
Joined Feb 20, 2016
4,641
Add a couple of diodes in series with the 5V out.
2 x 1N5004 diodes will work ok. Each diode will drop around 0.7V so the result will be pretty close.
ericgibbs
Joined Jan 29, 2010
21,567
hi,
I very crude charger using a 1R 3W resistor and two 1N5401 diodes in series could be made, powered from thr 5V power supply.
E
hardusb
Joined Apr 20, 2020
18
Thanks, will see what I can get my hands on, under lockdown so my options are limited, going to check for appliances I can strip for parts,
Dodgydave
Joined Jun 22, 2012
11,395
2.4V @1200mA sounds like 2 Nicads or Ni_mhis in series, you could put a 10 Ohms resistor in series with the 5V supply to drop the voltage easy.
Over Voltage wise, 4V probably ok.
hardusb
Joined Apr 20, 2020
18
I managed to get 6 diodes from an old set-top box and put them in series, it dropped the voltage to 3.5v from the 5v, its been about an hour and the device hasn't charged 1% even.
hardusb
Joined Apr 20, 2020
18
Just to be sure, I put them in series on the positive end like follows:
+5v in -->|--->|--->|--->|--->|--->|-- (Load)
- (load)
Load goes at the end of the diodes and the negative.
BobTPH
Joined Jun 5, 2013
11,645
I suspect that the charger is just that: a charger as opposed to a power supply. A charger limits its current and monitors the battery, cutting off the charge when it is finished.
If you apply 3.5V to a two cell NiMH battery, it will overcharge and destroy the battery.
NiMH is the most difficult chemistry to charge correctly. It requires either monitoring the temperature and cutting off the charge when it starts increasing steeply, or detecting a drop on the battery voltage of only a few millivolts.
You can safely trickle charge it at 5% of the capacity, in this case, 60mA. To do this, take your 12V supply and put a resistor in series to limit the current to 60mV when the battery is at 2.4V. The calculation is, based on Ohm’s law:
12-2.4 = R * 0.060
R = 9.6 / 0.060 = 160 Ohms.
Edited to add: Or with 5V, use 47 Ohms.
This will take about 24 hours to fully charge a depleted battery, so just keep it on the charger whenever it is not in use.
Bob
BobTPH
Joined Jun 5, 2013
11,645
While the device is charging the voltage is 2.4V, without the device charging its 3.54v.
That is because the charger is connected directly to the battery, as I surmised. You are basically reading the battery voltage. Follow the advice in my previous post or you will destroy the battery.
Bob
hardusb
Joined Apr 20, 2020
18
I see what you mean above, half of the mission here is to make a compatible charger so that in the future if I have a similar situation I know how.
The original Charger is rated 3.5v 1A, thus im attempting to replicate just that.
The original charge time was 16h. 24h is not that far off.
Closest I have now is 1 X 10 ohm, 1 X 11 Ohm resistors and one 23 Ohm, that makes 33 Ohms.
All other resistors I have is in Kilo Ohms.
hardusb
Joined Apr 20, 2020
18
After putting all these resistors in series I get 42.3 Ohms, voltage hasnt dropped at all, still 5v.
Charger is an Samsung mobile phone Charger with a USB Port. 5v 2A, got the extra 9v fast charging feature also but I think the mobile phone triggers that., I took an old USB cable and getting my power that way.
hardusb
Joined Apr 20, 2020
18
Its been on charge almost an hour now, the lcd display is just moved from 26% to 27%, so it seems to be working.
hardusb
Joined Apr 20, 2020
18
Its now charging at an rate of 1% every 35 Minuites, its now 29% charged, at this rate it will take 35 Mins X 71% = 2485 Mins = 41 .42 Hours to complete charging to 100%. This is a bit long. With the diodes it didnt charge at all, maybe too much diodes taking away all the charging current?
