Converting 380V electric motor to 220V
laposilaszlo
Joined Oct 6, 2017
Hi All,
I have bought an electric motor that is natively for 380V.
Can someone explain me if this can somehow reconfigured to work with 220V IMG_0087.JPG IMG_0086.JPG ?
Thanks,
laszlo
Dodgydave
Joined Jun 22, 2012
11,395
Your motor is wired in Delta, so you need to remove the three links and connect them Horizontally joining the three top wires together in Star,, then your Three Phases connect to the remaining wires.
To reverse direction swap any two phases.
38,814
Okay, I'm confused. :confused:
I though the phase-to-phase Star connection voltage was higher than the Delta.
