converting 120v dc to 24v dc
22,114
Sure, there are a couple of ways, the main ones to consider first are:
  1. Buck converter
  2. Flyback converter
  3. Forward converter
If those don't work, there are some exotic designs you can try.
ronsimpson
Joined Oct 7, 2019
4,845
That circuit will not get you 5A. Probably 5mA.
You need to ask the question: how do I get 120vac to 12V dc at 5A.
Also that circuit does not have isolation. It will get you killed.
Lo_volt
Joined Apr 3, 2014
374
Are you trying to experiment or to build something just to learn? Or do you have a project that needs 24 volt DC?
As ronsimpson says, that circuit won't get you 5A. There are plenty of wall-wart style power supplies available. Google 24vdc power supply to find a few.
panic mode
Joined Oct 10, 2011
5,308
upto 5 amps is fine im using this circuit rn to get 120 dc
no way...
you are not getting 5A through that 100 ohm resistor.
1Meg resistor is not significant, the Xc is about 1.2k so you get at best 120v/1.2k = 10mA
those 10mA are if output is shorted. if output is open, voltage will rise till 50V filter cap blows up. if it does not blow up it means capacitor has significant leakage current, in which case you still do not get 120VDC.
MisterBill2
Joined Jan 23, 2018
28,454
If the actual power source is AC, 120 volts, that makes the conversion much simpler. You will need a suitable transformer with the required current rating for the secondary, which in this case should be at least 5 amps. The secondary voltage should be at least 20 volts, 24 is better, and a four-diode bridge rectifier assembly.. OR you can get a transformer with a center tapped 48 volt secondary and you only need two of the expensive diodes.
Either scheme will get you 24 volts DC that will need some filtering. How much filtering will depend on the application of the 24 volt power.
That circuit shown in post #4 will result in a blown up capacitor and a burned out LED almost immediately after it is powered.
MisterBill2
Joined Jan 23, 2018
28,454
Indeed I did get one of those aluminum cased power supplies to replace an external computer supply that was destroyed by lightning.It was about $21 (USD). I don't recall the vendor. But it was a switcher supply, not sure how it would workto power a music system.
