Converting 0-2.5-5 voltage to 5-0-5 voltage ..#2
DickCappels
Joined Aug 21, 2008
10,661
A) AI is not your friend.
B) A little more detail is needed:
B1) Is the 5V floating or grounded?
B2) Do you mind winding a transformer?
Goksi
Joined Aug 16, 2025
6
can somebody tell me what can i use for lmv358a and bat54 i dont have this components in my town ..
ericgibbs
Joined Jan 29, 2010
21,571
Hi Goksi,
Please tell us what operational amplifiers are available in your country, also what types of low power schottky diodes are available.
E
Goksi
Joined Aug 16, 2025
6
hello,
i see in shop bat165 and bat43 schotky diodes, op amps have LM series ,TL series, mcp6004,lmv324 I or D , lm324 …
sghioto
Joined Dec 31, 2017
8,751
hello, i need same converter 0-2.5-5v to 5-0-5v which schematic works fine ?
P.S. ChatGPT give me this diagram with mcp6004
This is the circuit I posted from the earlier thread I believe is your objective.
EDIT: Added value of R11
sghioto
Joined Dec 31, 2017
8,751
R11 = 10K
Two 4.7K and one 100 ohm in series or just two 4.7K is probably close enough.:DR1 and R3 form a voltage divider to get 1.25 volts at + input of U1.
Any combination values of R1 and R3 to get 1.25 volts will work.
However in my case I needed to reduce the 1.25 volts to 1.20 volts because of an offset voltage on the chip, YMMV.
